Honda PCX Broke Speedo + Engine light on
Discussion in 'The Workshop' started by flash, Feb 2, 2021.
  1. flash
    flash New Member
    Hi all,
    As title, speedo doesnt move and engine light is on, it's a 2016 pcx.
    Any ideas? thought Honda's were bombproof :(
  2. Stevep
    Pretty sure your speedo is digital on that. Which means that if the speedo drive isn't sending the proper signal then the ecu will pop a check light.
  3. flash
    flash New Member
    Hi Stevep,
    It's not digital pal, it's the 'sweepy' needle! I pulled it apart today to check the wiring but couldnt see anything wrong.
  4. Stevep
    When I say digital, I don't mean the speedo reading is digital, I mean that you don't have a conventional speedo cable as such.
    You have a speed sensor with three wires coming out of it. Possibly the sensor is faulty.
    Check the Honda PCX forums, plenty of the same troubles on there
  5. flash
    flash New Member
    Ahh right got ya, yes the sensor has 3 wires going to it. I'll order a new one and hope for the best!
    Cheers.
