Hi there fellow riders. I currently have 20x15 12.5 roller weights in my honda dylan 125. But recently come across bussiness advertising 20x14,6. So forget the weight totally for a moment. What would happen if I change from 20x15 to 20x14.6 . If it helps the brand is malossi Waiting for your help and advice. Thank you in advance.
It's not the weight I'm enquiring about it's the size. I have 20x15 But there our also 20x14.6 What's the difference.
Ok. I see my error there. I should be asking will the 20x14.6 still fit my moped.? Even tho my current ones our 20x15 and what difference does it make to my moped.?
Your Dylan has a similar engine to my old PCX125. Standard size is indeed 20x15. Malossi list the PCX/Dylan as being 20x14.6 for some reason and only sell rollers in that size - I can tell you if you fit the 14.6 rollers they will not rattle and will work absolutely fine. I couldn't tell any difference in size visually compared to the Honda ones so perhaps Malossi are just a bit more accurate in how they measure...dunno. I have used both the 12.5 and 10.5 rollers Malossi do. FYI; 15g is best for overall mpg but poor if you live somewhere hilly. 12.5g makes it a little nippier, better on hills will no real effect on mpg 10.5g made the bike drop 10-15mpg, though it'd reach a higher top speed. Malossi yellow clutch springs will help your bike a fair bit as well on take of with the 12.5/10.5 g rollers.
