hi noob here :)
Discussion in 'Introduce Yourself...' started by rudeboycm, Apr 4, 2012.
  1. rudeboycm
    rudeboycm New Member
    Hi every1 :) I'm corey, just stated tuning a mbk rocket. I'm 21 car mechanic,spelling is shocking lol so please ber with me :). Well I started tuning the rocket for fun tbh as its was cheep 120 pound ;) piston, and rings we're foooked,split engine blow all bit of old piston and rings out,gave her a good clean then put a polini sport 70 kit on :) next was the polini team exghurst :) and then tnt 21mm carb (90 jet) is that okay? Runs mint seams fine just askin? :), o and a pipercross spunge air filter to let her breath lool, need your help her guys as for the gearing I've only changed clutch springs at the min to (mollosi red springs) .. It would still set off at low revs :confused: so I thourt rollers? Its got 6x 3.9g in atm as that's all I've got,... I tuck 3 out she revs mint but still not mutch power,belt looks a bit saggy(maybe stretched?) Please help people, progress blog and pics will come up to night at some point :)
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    Replace belt/cluch. Probably warn out by now.
  3. rudeboycm
    I'm going to change the belt this week some time see what happens, clutch looks mint lots of life in that left
  4. Jonnymarrw00t
    Standards can slip on 70's mine did.
  5. rudeboycm
    Oo I'll try ruff it up see if it's that then (thanks bud)
  6. Stathis
    Nrg Power 70cc
    Hello! welcome to the forums!! :)
    you should also put a reed prefer a malossi one with carbon reeds... so more mixture will enter the cases... also put the yellow malossi clutch springs... they are mad! and you should look for a good variator for your set up and a clutch spring (the big one) also at my 21mm carb i had 88jet.. but depends on the setup :)
  7. rudeboycm
    That's for that buddy :) I have put so carbo reeds in they came with 70 kit :) dot you no if the stage6 viriator any good? And would you recomend a kevlar belt? Thanks agen
  8. Jonnymarrw00t
    All belts are kevlar. But you should get a new belt yes. Stage 6 bits are very good.
  9. rudeboycm
    Sound cheers fella
  10. Stathis
    Nrg Power 70cc
    yep jonny is right! ;)
