hey need help light bulbs keep going grrr
Discussion in 'Bike Chat' started by jordz888, Mar 15, 2011.
  1. jordz888
    jordz888 New Member
    sym jet 50
    hey guys so i got a motorhispania yees they r shit but i got it cheap first i took the engine out stuck in a rx 50 engine that i had lieing about then addd a 70cc bore kit k and n air filter up jetted etc runs perfect :p .now for the rubbish bit this bike was made with no battery grrrr chinsse cant make bikes for shit lol.
    to get to the point my blubs keep blowing put new ones in and still keep blowing
    help please any ideas thanks jordz
  2. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    You fitting the correct bulbs ?
  3. Surferdude
    Surferdude Member
    Area 51 50cc w/c
    Rectifier?
  4. jordz888
    jordz888 New Member
    sym jet 50
    yeer fitted the correct bulbs think it might be the reg
  5. m1ck_t
    alot of shit
    Didn't think it would have a reg/rec if it doesn't run a battery, i know fa about them systems tbh
  6. jordz888
    jordz888 New Member
    sym jet 50
    yeer its got no battery and still has a red confused dont wana but a reg then it dont work.just gonna get it fixed then sell the fucker :L
  7. wobbly_trials
    forgive me if i'm wrong but it should run a battery.
    if the battery has been taken out the reg/rec unit will have been working very hard to cope with the engine voltage therefore will go pop and your output will exceed the usual 14 volts max.
    if its not supposed to run a battery then the power box (glorified reg/rec unit) is possibly on the blink. worth getting it tested.
  8. stkflote
    stkflote Member
    zip 2t cat
    what model is the hispania because if it the geared bike they have the aprilia AM6 engine in them and they def should have a battery
