HELP!!!!!!........
Discussion in 'The Workshop' started by grindey5490, Mar 28, 2007.
  1. grindey5490
    grindey5490 New Member
    Right me and a mate were ridin' round today when we went passed a field with a few pit bikes racin' round...
    ...and we decided to join them. But on our peds. I was great fun and a good laugh but :D ...
    Now my ped wont work!!! :( I was going to go out tonight when it wouldn't start. Checked fuel as it's getting low but there is plenty for a small journey, cleaned up spark plug etc and got it running again. But the problem before was it splutters on low revs, now you have to constantly full throttle or it dies. So could anyone help me please!? :nerd:
    Bare in mind the field was very bumpy lol and yes I have learnt that peds should stay to the road!!
  2. wobbly_trials
    sounds like a compression issue to me, does the kickstart push down easier than it didand is the bike harder to start. checkyour crank seals and top-end compression
  3. grindey5490
    cheers wobbly yeah the kick start does seem a bit easier.
    How do I check my crank seals? Is it easy enough, never done it before!
  4. wobbly_trials
    if the kickstart is easier it's more like top-end. to check this, take the plug out and cover the plug hole with your thumb and thurn the motor over. it should blow your thumb off the hole. if not then top-end compression is down
    to check crank seals you will need to remove the variatorand the crap behind it and see if there is a "Wet" patch around the seal and the same on the flywheel side.
  5. grindey5490
    Yeah I think it's prob top end. Is the only cure to change barrel + piston? If so maybe time for a 70 kit. :D
  6. wobbly_trials
    probably onlyneedspiston and rings. cheap job.
  7. grindey5490
    ok cheers wobbly. :up:
