Help!?
Discussion in 'The Workshop' started by Charlie Butler, Nov 21, 2019.
  1. Charlie Butler
    Charlie Butler New Member
    My chineese 49cc moped drive belt shredded. I put a brand new one on and it lasted 1 and an half-ish journeys. What could be causing this?
    Thanks in advance.
  2. Dominic Challinor
    Dominic Challinor New Member
    abrasion, excessive heat from something or incorrect length.
  3. MARSH
    Check the rear clutch, if it's worn it will take out drive belt, cheap enough to replace the whole transmission.
  4. Damjan
    Damjan Active Member
    Baotian Falcon 50R
    Belts shredded is caused by variator / variator ventilar or the torque pulley no other thing as clutch can cause that.
  5. MARSH
    Yes what Damjam said, it's the torque pulley not twisting as it should but just fit a new clutch unit complete !
  6. Damjan
    Baotian Falcon 50R
    It can be the variator as well everything needs to be disassembled and checked.
  7. Stevep
    Normally the small needle bearing in the clutch pulley fails causing the entire clutch unit to run out of line. I've never managed to change one.
    As stated above, just replace the entire clutch pulley unit, dead cheap.
    Also check the input shaft bearing in the gearbox for sideways movement (3 o'clock/9 o'clock) as this can cause the same problem.
