iv just replace my throttle cable on my aprilia rs50. and the new cable seems to be shorter than the old one. and the old cable went round from the left hand to the front end past the clutch lever past the igintion barrel (which its in the middle) past the front brake lever to the throttle. so i have put the new one on put i have had to go a sort way through the right hand front damper to the carb as i cant go around like the old cable.. iv checked to see if its the rite one and it is .. any ideas
A long as you can turn the bars both ways to the stops without it tightening or catching, it should be fine
