HELP!
Discussion in 'General Tuning' started by OllieTGBR50X, Aug 27, 2011.
  1. OllieTGBR50X
    OllieTGBR50X Member
    TGB R50X
    SO I HAVE A TGB R50X 2010 EDITION IN YELLOW AND BLACK, IT HAS AN AIR BOX ON THE SIDE, IS IT POSSIBLE TO JUST BUY ONE OF THESE FILTERS
    http://www.ebay.co.uk/itm/TGB-CHROM...95?pt=UK_Motorcycle_Parts&hash=item3f0cc6ce5b
    I KNOW THIS PARTICUALR ONE IS 28 - 35MM AND IM NOT SURE IF IT WILL FIT, ILL CHECK BUT IS IT POSSIBLE TO JUST TAKE THE BOX OFF AND ADD THIS?
    SOMEONE SAID SOMETHING TO ME ABOUT NEEDING TO RE TUNE MY CARB BECAUSE ITS FUEL INJECTED OR SOMETHING, NOT SURE WHAT THEY MEAN. THANKS :)
  2. Sloba Serbia
    Sloba Serbia New Member
    take of your box and mesure the carburator...and see if will fit...:p
  3. brettfield999
    brettfield999 Member
    Typhoon 172
    Or you could just not do that and not put a filter on at all. This is correct the fuelling (carburettor jetting) would need to be uprated because the is no ecu to regulate and adjust for the increased airflow you will get. Faikure to adjust yhe fueling will result in poor performance, overheating and eventually seize. An airfilter is not useful as a performance upgrade until a larger carb is fitted, which would be a waste of money for your bike
  4. Jonnymarrw00t
    Piaggio Zip 05 plate
    + K&N Filters are SHIT. Just thought i'd add that in....
  5. OllieTGBR50X
    OllieTGBR50X Member
    TGB R50X
    HAHA Thanks haha, thanks for all the info guys :))
  6. tErr0
    Again title your topics properly or they will be removed.
