Hi, I have a Yamaha Aerox R 50CC 4 Stroke, I believe it's the 2016 model. I want to buy a new exhaust and maybe do some other things, do you guys have any suggestions?
Same engine as the neos To make it faster you can change the vario. To make it really fast remap the ecu.
as above and welcome to the forum. fourstroker pipes : more so purchased because they make that brap brap sound , that deep low gurgle you hear from a sporty pipe on fourstroke bikes, they do not release more power as much like a twostroke exhaust does and the reason is the fourstroke engine has a valve set so they do not require back pressure tuning on a pipe. save pennys change variator to a high speed version , malossi - polini , remap the ecu to lift the rpm restriction somewhat and enjoy. please remember its only a little scooter ie its a small engine fourstroke so they tend to have more in torque than all out raw power like a twostroker version
