HELP WITH TUNING SETUP.
Discussion in 'General Tuning' started by Bradley Nixon, Mar 15, 2012.
  1. Bradley Nixon
    Piaggio NRG Power DT
    So here's the set-up that i'm wanting..
    Malossi sport 70cc Kit. - £130
    Polini hi speed variator kit. -£40
    Yasuni R Exhaust. -£140
    Polini air filter 37mm (covered) -£17
    Stage 6 primary gear up. -£56
    Malossi belt. -£30
    Malossi Delta Clutch & Clutch Bell Set -£87
    Malossi clutch springs. -£15
    YSS Mono X-Pro Shock Absorber -£40
    Malossi brake calipers. -£ Around 20
    Stage 6 Quick Action throttle kit. -£45
    but the thing is, some of the parts on here are for 'Mid-Race' Setups, some are for 'Race' Setups, and some are for 'Sport' setups. Would it matter to mix them all up? PLEASE HELP.
  2. Sketchytom
    Sketchytom Roach
    Rally 50 you get me
    seems alright to me. i would keep the stock air box personally and ditch the quick action unless you get a larger carb as it will be like a on off switch lol
  3. roxy boy
    roxy boy Well-Known Member
    roxi
    Don't get an open air for a cast iron on a standard carb waste if time tbh and 4get the quick action ..
