Hey, I'm running this setup on my 99' sr: This is my setup: Malossi MHR 70 kit(recently died on me, new one is on it's way). Malossi MHR crank. Malossi Delta clutch, and malossi multivar(no over range). Malossi exhaust. Malossi CDI. 2 Wave disks. 17.5 Delor'to carburetor. stock air filter. As I'm already ordering a new cylinder kit I've decided to also upgrade my carburetor and air filter. I'm in a deliberation between the 21mm bgm flat side, the 24 mm bgm flat-side, the 22mm Malossi non-flatside, and 25mm Malossi. which one should I use? I was told that non-flatside crabs are easy to set yp and tune, Is it correct?. Which filter and airbox(winter is coming) should I use? . Thanks in advance, Oleg.
I'm thinkning about this carb: http://scooter-center.com/catalog/produ ... s_id=11182 Is there anyone here who tried this combination before?(MHR KIT + this carb), which manifold, airfilter and jets did you use?.
its a flat SLIDE carb, not side just get a dellorto, good cheap carbs , dont bother with malossi's there just dellortos with a malossi stamp on them this should do niceley http://scooter-center.com/catalog/produ ... =4403_4414
