Just got the malossi 172cc kit for my sr 125 and in the manual it says something like you can upjet if you like otherwise just raise the needle on the carb what do you people sugest i should do also i have a Kundo race pipe if that helps. And if it is the carb needle that needs adjusting do i move it up or down ? Thanks for your time.
just upjet and leave the needle where is (if you still have the stock airbox) dont really need to upjet for them usually but on the ac its probably a wise move to go up a couple sizes.
