i need to wire up my mkt under tray which i purchased 2nd han ny one help me by tellin me wat wire are what
Assuming that the tray is purely indicators it's a fairly streight forward swap, connect the indicator wires from the left side indicator to the left side ones on the tray and the same with the right ones (unless you want to wire them the wrong way round for shits n giggles) if it has a stop/tail built in you need to establish which wire is the earth (goes to the outside of the bulb, then connect to the earth on the tray (usually a green/yellow or black wire) then its a case of turning your ignition on, holding the brake and sussing which wire is for the brake light and the one left is for the tail light. (brighter one is brake, dimmer is tail) connect them one way, if the brighter one comes on with normal lights then its the wrong way.
no wobbly its the one with built in lights and indies i used to have it and it was a bit of a slut to wire up, i just gave up in the end and stuck my arm out lol.
dec the one i got off you was wired up right mate, just needed an led indicator relay if its for a rox and mhr rox needs one ive got one with a few other bits in swapshop
once you have it wired correctly the indicators wont flash at the right speed or flash at all, so you will need an led indicator relay
