Help * Typhoon 160cc 2 temps * HANDLES VIBRATION
Discussion in 'The Workshop' started by binhpv79, Apr 3, 2013.
  1. binhpv79
    binhpv79 New Member
    Hi,
    Wonder why my bike the Piaggio Typhoon 160cc 2 temps is so vibration at handles.
    I've checked the oil & gas, variator & clutch, piston and crankshaft even renew the 2 wheels.
    Please advise me if you met it before.
    Big thanks/ Jason
    PS: here some pics of my passion. How is my 360 pipe which was hand made by our guy :)
  2. creamsodauk
    creamsodauk Ped Ped!!
    Runner 125 SP
    have the tires been balanced?
    vibrations could be due to a buckled/dented wheel
    worn engine mount bushes
    worn swing arm bushs or the bushs can be too tight
    worn silent bush
    binhpv79 likes this.
  3. ramo
    ramo GoldMember
    How did you get 160cc?
  4. binhpv79
    binhpv79 New Member
    Hi Ramo & Creamsodauk
    1. Iv widened the piston (60)
    2. Then Iv change this to fix it wz piston size:
    3. Then I replaced the secondary gear as it:
    4. Iv change the carburetor to 28mm wide mouth and air filter:
    5. Now I think I should change:
    a. Piston to 68 wide (full kit)
    b. Lengthen the crankshaft to 1.5
    And also check the advises of CREAMSODAUK.
    "have the tires been balanced?
    worn silent bush "
    *** Will update u soon.
    Tks fr Jason/ Vietnam
    ramo likes this.
  5. creamsodauk
    Runner 125 SP
    let us know how the gear up kit goes
  6. binhpv79
    binhpv79 New Member
    when i tested: it went slow when departure and i feel the engine is so weak (lack of power). The gear is Malossi so that is why i need to widen the piston to 68 ??!! to make the engine more poweful!
    When the bike was original one, i drove it also vibration much :(. and when Iv tuned it as the above, and change the wheels & carburetor (fr 25 to 28mm mounth). This vibration is decreasing but it still.
    Thanks much for your attention because in our country Vietnam, I think only me restrore this bike ;), that is why noone might help me here!
  7. greg531
    greg531 Member
    First, get a set of street tires, those knobby tires that come OEM, ride bad.....I put a set of
    Pirelli Sl26 Scooter Tires on mine.....Then, I would get some aftermarket shocks.......
    I don't think the plastic's have much to do with the ride, except for aerodynamics at high speed....and maybe the extra weight would help the bouncing......
  8. binhpv79
    binhpv79 New Member
    Hi greg,
    Tks 4 ur adv, ll keep trying.
