Help! typh 50cc bog
Discussion in 'Scooter Tuning' started by Anton Kash, May 10, 2011.
  1. Anton Kash
    Anton Kash Member
    Typh
    Today I just baught a typhoon and it bogs most of the time.. sometimes its fine for a couple of seconds then it bogs, I usually have to do 1/4 throttle and gradually build up my speed but then bogs. It's all standard with a leo vince ZX, as I baught it today I don't know what weights rollers, springs and if he upjetted it or not? What jet should it be, what rollers and what springs, what else could be making it bog? Thanks.
  2. creditz
    creditz Member
    Speedfight 50 AC
    If it's all standard, it sounds like a carb problem. I'd clean it out and then look at jets. When you clean it; post here what size jet is in it.
  3. Anton Kash
    Anton Kash Member
    Typh
    okay, will do, does it say the size of the jet? and also it has a zx so i should of been upjetted but i duno if it has ( dont fink so ) checking jets now
  4. Anton Kash
    Anton Kash Member
    Typh
    I just opned it up and put it back together but its not starting now... the jet is a 53
  5. MiNoR cOnFuSiOn
    up to a 60 jet, when you have the bottom of the carb off make sure the float pin is in place as if its not your carb will get no fuel. remove the black pipe from the carb (second biggest) that runs to the fuel tap, suck this and it opens the fuel tap letting fuel into the carb. this is probably why it hasent started. kicking it is real hard way to fill a carb up. need to start around the 5.5g. does the bike actually have an airbox?
  6. Anton Kash
    Anton Kash Member
    Typh
    okay ill try what u say, yes the bike does have an airbox, however its off atm, i dont think this matters because when it did start it would start with the airbox off
  7. Anton Kash
    Anton Kash Member
    Typh
    okay i got the bike started again.. ill try jets upto 60 when i get them, what else could it be if its not the jets? ( probably is )
  8. gileraskp95
    gileraskp95 New Member
    gilera stalker 50cc
    i would advice putting the air filter back on and buy a polini air filter
  9. final178
    final178 New Member
    gilera runner
    do the jet first and put da air box back on and go get ur self some 5g rollers put them in and then kick it
  10. Anton Kash
    Anton Kash Member
    Typh
    i only had a 70 jet that I found.. tried that but that was too much. I'm buying a jet pack ranging from 52>60 something. This will be good for me i recon.. I'll also get 5g - 5.5g? what grams should i get?
  11. RIGZ.172
    RIGZ.172 Member
    camel
    get 3 different weights and check which 1 is the perfect for you as every1 has there own choice.
  12. Anton Kash
    Anton Kash Member
    Typh
    I should jet it first then do the rollers? because right now its not really ride able..
