HELP STARTING BAD! NEED IT ASAP!
Discussion in 'The Workshop' started by Vap0ur, Jun 8, 2007.
  1. Vap0ur
    Vap0ur New Member
    right, my scooter wouldnt start this morning, so i thought it was because it was cold.. when i got home it was hot so it should have started, yet it didnt and the battery died.., i went and got a new battery for the bugger, did exactly what it said, and hooked it up right nd everything, yet it still fails to start ! I think its ticking over.. well im pretty sure as i can hear it.. yet its not starting.. anyone help me, i need my ped back asap as i need it for work 2mrw and sunday!
  2. Vap0ur
    Vap0ur New Member
    right i reckon its the spark plug as im pretty sure im not getting a spark..., i had a 70kit fitted so might need a dif plug.. what plug shud i get for a 78 jet.. on a gilera runner..?
  3. nrgandy
    nrgandy New Member
    think its ngk br9es do a search and you should find out
  4. skatergod
    skatergod New Member
    lol like i said to u in that txt ay mate... br9es.... same as i had in my runner 125... :bird:
  5. dezze
    dezze Member
    yeah first thing you should do is take the plug cap off and put the ht lead to an earth on the bike (frame will be fine) then turn it over if u get spark try changing the plug then if that dont work then your plug cap is gone.
    if you dont get a spark that means iether your coil is bust or something electical. you will need a multi meter to check the coil . if u still have the problem !!
  6. Major Rel14b1lty
    Major Rel14b1lty New Member
    do u have a open air filter?
