Finally I have got all the lights working on my runner. My only problem is indicators will only work if head light is on?? Why is this how can I fix
Ive had loads of probs with mine recently. Only thing I can suggest is to check the earths, next to regulator, on the frame above the flywheel and on the other side of the frame. If no joy maybe print a wiring diagram of the net and check the wiring are all right, I no before my runner had a new battery it seemed to do strange things! Hope this helps somehow! Good luck!
You've got a power circuit crossed somewhere. The headlight is powered through it's own relay. The indicator circuit is quite a simple thing. Power into the relay, power out the relay to the switch, power out the switch to each side of the indicators and an earth to each one.
