HELP PLEASE! ZIP 50 2 STROKE!
Discussion in 'General Scooter Discussion' started by rovers12, Mar 8, 2012.
  1. rovers12
    rovers12 New Member
    piaggio zip sp70
    I HAVE A 2009 ZIP 50 2 STROKE, I CAN HEAR A CLICKING NOISE NEXT TO BACK WHEEL WHEN I SET OFF, BEEN TOLD ITS ROLLERS, COULD SOMEONE PLEASE HELP ME? AND IF IT IS ROLLERS WILL IT BE ALRIGHT TO PUT LIGHTER ROLLERS IN TO REPLACE THEM? ANY HELP WILL BE MUCH APPRECIATED, MANY THANKS :)
  2. Stig
    Stig Well-Known Member
    EXUP1000
    could also be the belt with a bit starting to break off
  3. Stathis
    Nrg Power 70cc
    Please stop writing with CAPS LOCK! Thank you :)
    yes it could be the rollers or the belt as mister stig mentioned :p
  4. rovers12
    rovers12 New Member
    piaggio zip sp70
    Okay thanks alot for the info :)
    do you know if it will be okay to put lighter rollers in? and do you know any way i could make my zip faster without getting 70 kit? thanks
    and by the way only upgrades is exhaust and its de restricted :)
  5. Stathis
    Nrg Power 70cc
    well about the rollers depends... does it ride allright now or you are having problems?? what gram rollers you have???
  6. rovers12
    rovers12 New Member
    piaggio zip sp70
    it rides fine now, and iv not had it long and previous owner said its got 3x 6.5g and 3x 5g in now, thanks
  7. Stathis
    Nrg Power 70cc
    looks like the rolles are fine so you dont have to put lighter ones, you will lose power.
  8. rovers12
    rovers12 New Member
    piaggio zip sp70
    fare enough, i just want to get rid of the clicking noise
  9. Stathis
    Nrg Power 70cc
    yep i know ;)
  10. rovers12
    rovers12 New Member
    piaggio zip sp70
    is tere any way i could get rid of it amd still have roughly same power as i do now? cheers
  11. Stathis
    Nrg Power 70cc
    just replace the belt and rollers to the same ones... hope that will work!
  12. rovers12
    rovers12 New Member
    piaggio zip sp70
    okay thanks alot for the advice buddy :)
  13. Jonnymarrw00t
    Piaggio Zip 05 plate
    If it's coming from the back it'll be gear oil or clutch. I'd check your clutch isn't warn out. You shouldn't have mixed rollers so order 5.5's For what you'd spend to get more speed you'd get more spending 97quid on a polini sport. Take this from somone who's learnt the hard way.
  14. rovers12
    rovers12 New Member
    piaggio zip sp70
    how do i check that? lol amd will 5.5s be alright? thanks
  15. Jonnymarrw00t
    I ran 5's with a tt so 5.5's should be good. and you take the clutch bell off and see if it's worn down ?
