help needed gilera 180 engine in typhoon
Discussion in 'The Workshop' started by typhoon180liquid cooled, Jul 15, 2013.
  1. typhoon180liquid cooled
    typhoon180liquid cooled New Member
    dno were to start brought a 125 typhoon hammered dropped the engine and sold the brought 180 engine cases and fitted the following parts pm 52 crank brand new 180 barrel brand new piston used mallossi head brand new bearings water pump and seals pm carbon petals polini inlet 25ml delorto pm variator mallosi belt lightend fly wheel but running standard clutch and exhaust engine is basicly a new engine fitted in the typhhon but had to remove smaller fuel tank at the front to fit radiator in so now unsure were to run fuel lines ect ino there is a nipple of the engine cases witch blows air into the fuel pump witch pressures fuel into the carb but ive stripped all that off whats the best way to do it some one mentioned a t piece or somthink any ideas need to get this bike done and finished its a nightmare
  2. ramo
    ramo GoldMember
    50cc fuel tank and a piece of hose with a screw in it for the vacuum nipple?
  3. typhoon180liquid cooled
    would that work and you mean a typh fuel tank i am thinking now to get a tank made for under seat and have gravity fed to the carb with a fuel on and off switch isnt it bad for the engine to block off the vacum nipple build up of preaseure in the engine
  4. ramo
    ramo GoldMember
    Nah if you block the nipple properly it'll work like it's not there. Or could use if for the fuel tap if your carb doesn't have one..
    There's lots of ways to do it 50 tank is probs easier if anything(cheap, bolts on, gets rid of 2nd tank pipes)
  5. MARSH
    just block off the union on the engine case just below the reed block, block off the large+small petrol pipes on main tank, run the vacuum pipe, petrol pipe to carb.
  6. typhoon180liquid cooled
    sorted now lads just running gravity fed tank under the seat and blocked of the engine vacum with pipe and bolt just need some jets now for a 25ml lol
