HELP MY TYPHOON OUT
Discussion in 'Scooter Tuning' started by The General, Oct 30, 2007.
  1. The General
    The General Member
    Right I want to add a few more performance parts but im unsure what to add. I'm not ready to fit a gear-up kit in my bike yet I want something else can anyone suggest anything thats gonna add some power :bird: want to increase top end speed a bit because acceleration is pretty decent i know i can get a bit more out of it aswell without a gear-up kit so help me out guys.
    P.S What benefits would a malossi or polini performance clutch give?
  2. haugh
    haugh New Member
    You want more top end speed but your not ready to fit a gearup?
    You've got a Malossi Sport kit and your on standard gears so you wont be getting any more top speed are you?
  3. The General
    The General Member
    Be quiet haugh you no nothing.
    Of course you can get more speed i've got mates that fly past me without a gear-up so why can't i keep up there is obviously more stuff to improve POWER.
    You haven't tuned your ped up one bit so you are not in any position to tell me to get a gear-up especially as I said dont mention a gear-up, thankyou pleash.
    :bird:
  4. monty9120
    monty9120 Active Member
    Vespa gts300
    ac are geared lower then l/c to start off with. so mates on runner 70s will beat you top end
    gear up is the only answer :pimp:
  5. The General
    The General Member
    but i dont want to lose my acceleration :(
  6. monty9120
    Vespa gts300
    well sorry it depends how well the bike is set up
    ive been on 172s that i never knew had gearup until i got to 70 and it carried on going :w00t:
  7. The General
    The General Member
    Ok looks like im going to HAVE to purchase a gear-up if I want any more top end speed then but im talking a bit more ooomph.
    Someone said they had a polini variator kit that added nearly 10mph (8mph) onto their top end, what kit was that?
  8. Jamie
    probs the speed control kit
    with the belt and variator and etc
    i think its slightly longer so adds a bit more top end
  9. capri dave
    capri dave Active Member
    An over range kit would add top end without loseing acceleration!!!
    you get an oversized variator, rear torque driver and a longer belt...bit pricey though ;)
    minor once told me a gear up is a waste on a sports 70 kit....
    so youd want a better 70 kit to rev on and then a gear up!!!
    EDIT...what carb you running?? a 21mm carb kit would give you more oomph...if you havent got 1 already!!! my 20.5mm literally increased my top speed by 5mph or so over the weber 12mm ;)
