Help me with variator and clutch!
Discussion in 'Scooter Tuning' started by Stathis, Mar 30, 2012.
  1. Stathis
    Nrg Power 70cc
    Ok guys im having a major problem the last few days, i turned the Nrg to 50cc standard but i left on the following:
    -Malossi racing clutch bell
    -Malossi yellow clutch springs (the little ones)
    -Purple malossi spring (the big one)
    -Malossi multivar 2000
    and about the rollers i dont know i have forgotten :p
    my problem is that the scoot isnt working as it should and its drinking a lot of fuel for no reason..
    what do i need to keep?? what do i need to change?? Please advise as im very confused with this shit...
    All the comments welcome! thanks :)
  2. Bradley Nixon
    Piaggio NRG Power DT
    I don't think it will be the clutch bell or springs, unless the racing clutch bell is for 70cc kits? that's my only prediction man :(
  3. revolution
    revolution Member
    did you jet the carb again to suit if you removed a bore kit?
  4. Bradley Nixon
    good shout revolution.
  5. Stathis
    Nrg Power 70cc
    im gonna do that and remove the purple spring and put the standard back on and see how it goes... also change the rollers wish me luck
  6. Bradley Nixon
    It'll be fine man, good luck
  7. Jonnymarrw00t
    Piaggio Zip 05 plate
    Put your pipe back on. Doesn't use much more fuel.
  8. Stathis
    Nrg Power 70cc
    what pipe mate?
  9. Jonnymarrw00t
    Your performance pipe ?
  10. ramo
    ramo GoldMember
    The clutch on a pretty much stock 50 is best pretty much standard with maybe slightly stronger springs i have found. Rollers and jets can vary alot obv
  11. Stathis
    Nrg Power 70cc
    Thanks for the replys guys :)
    Jonny i have a gianneli reverse on it right now, also i did some work today i removed the purple big spring removed the clutch bell, the multivar 2000 putted all the stock shit back on it works fine but i still have to change the clutch springs since it gets right away at the final gear... (the clutch springs i have now on are the malossi the yellow ones)
  12. Jonnymarrw00t
    Dude, You have the parts, use them! Wack the clutch on with slightly stronger clutch springs, Put the variator in, put some 5.5g rollers in, 68 jet and bam. Decent ped.
  13. Stathis
    Nrg Power 70cc
    you think??? i had the setup that i mention above and the scooter was doing some crazy senseless fuel drinking... :confused: for no reason... it was running terrible.
  14. Jonnymarrw00t
    I don't see why you were using so much fuel :confused: ? Did you have a open air filter ?
  15. Stathis
    Nrg Power 70cc
    nope i had the box.. :confused: it was so weird i dont know either.. its getting on my nerves :mad:
  16. Duggiedan
    Duggiedan Piaggio zip 50cc
    Piaggio Zip
    do you have standard carb on bigger one? do you have a fuel leak and think its drinking it?
  17. Stathis
    Nrg Power 70cc
    no no 17,5 mm carb ;) and i dont see any fuel leak... i mean where i park the scoot i dont see any fuel under... so ;)
  18. Duggiedan
    Piaggio Zip
    sure people arnt taking fuel out of the tank cause of the fuel strike business ;)
    Bradley Nixon likes this.
  19. Stathis
    Nrg Power 70cc
    haha yeap im sure of that aswell since if you take the pipe out where it connects to the carb fuel cant come out :p
    piaggio technology :cool:
  20. Duggiedan
    Piaggio Zip
    :eek: mine does :confused:
