HELP! Is there any way of getting a petrol cap of an aerox without the key
Discussion in 'The Workshop' started by aeroxtomz, Nov 6, 2012.
  1. aeroxtomz
    aeroxtomz New Member
    Aerox
    broke my two keys one is in the acttual ignition and i lost the other one but i was wondering is there any way of getting the petrol cap of without the key ?????
  2. Edgar
    Edgar Active Member
    drill the lock out u will still gona heve to replace it, no other way really i think
  3. A-LY
    A-LY Active Member
    maybe if you could get the key out the ignition you could poke it into the fuel cap and turn it using the rest of the key or a set of pliars depending on where it snapped
  4. Stig
    Stig Well-Known Member
    EXUP1000
    or even take it to a local key cutter and have a full one cut :confused:
    if you do get the part key out, give the lock a spray with wd40 before you try another key. Once its off, lube locks with powdered graphite
  5. A-LY
    A-LY Active Member
    i thought key cutters only did like house keys?
    or is that my local weing a bellend
  6. Stig
    EXUP1000
    theres keycutters and theres KEYCUTTERS (insert LOCKSMITHS)...the latter can dismantle a lock to its basic levers and build the lock to fit a key of your choosing.
    The former will just copy a key to a blank on a machine. They're usually folks like cobblers/shoe shops that have expanded into alternatives now that everyone buys disposable shoes instead of having quality items resoled
  7. wedgie
    wedgie Member
    Mk 1 Zip SP
    When i fucked my petrol lock on my rox i just shoved a screw driver in there and it snapped the lock inside. so i could just undo it with any key. not the best thing ever, but it worked for 2 years haha still working now :D
  8. Stig
    EXUP1000
    if the locks are weak enough to be forced that'll allow you to gain access and be able to change the lock cylinder for a new one with key
