hi posted on here few times as haven't been able to sort out scooter was running rough so i drained down tank cleaned out carb removed restrictors changed to larger jet due to sports exhaust/filter new fuel filter now the dam thing wont start turns over but dont fire removed plug checked spark ok checked fuel and fuel going into carb ok anyone please advise as getting to the end of my tether with this as not got any experience with scooters also worked on my cars for years it is peugeot speedfight3 50cc
First off, try a brand new plug. If you try and start a load of times they will stop sparking under load... Then after that test the compression... One thing you can do too. Is take the plug out, and blow down the plug hole with an airline and turn the engine over at the same time. It will blow all the fuel out the case and give you a fresh start with new fuel mix in the motor when you put the plug back in.
