HELP!! Engine cut out after rebuild?!
Discussion in 'Newbie Scooter Tuning' started by Samuel Hornsey, Nov 26, 2011.
  1. Samuel Hornsey
    Samuel Hornsey New Member
    hi all
    need abit of help please? i have completly rebuilt my piaggio nrg dd engine (crank, bearing, cylinder ect) and connected everything back up but when i start it it revs itself quite high then cuts out in like 5 seconds, is it oil starvation? the oil tube has full oil in it to the carb but just need some advise?
  2. tErr0
    Make sure the carb is all connected up correctly. Leave the airbox/air filter off and check the silde is all the way down when trying to start it.
    It's always a good idea to run a bike through at least one take of premixing with the oil pump connected when fitting an engine or doing a rebuild.
  3. Samuel Hornsey
    thanks mate ill go and give it a go :) and well ive connected up the breather and fuel pipe and also the oil pipe but theres two pipe holes left over with no were to connect them to if you know what i mean?? (standard carb)??
  4. tErr0
    There are two overflows if you are talking about two that look the same. They are left as is.
  5. Samuel Hornsey
    ye them two look the same :) so thats the connecting ruled out, ill check the slider now, and ill drain the tank out and refill with premix, thanks for your help, sam
