hello I want to replace gear oil in my 2007 peugeot trekker, and I see only one screw on the engine block .. Someone might know and can help me how am I supposed to replace gear oil in this scooter ?? tnx.
Should be a bolt under the back of the transmission case right by the brake adjuster?look for any bolt that points to the floor around the rear wheel gearing.
As above its probably a sealed system that you just monitor the level of. The fill level is usually the thread of the filler which sits at an angle so top up until it dribbles out. If you want to change the oil then you will be looking to get a syphon tube and pressurised hand pump or large syringe to suck it out.
It behind the rear wheel.. look dead on at exhaust behind the wheel that way I mean.. some you can get to it by going threw wheel some times you have to remove the wheel for a better access.. drain from there and fill from top dip stick
