HELP carburetor repair kit! SOLVED
Discussion in 'General Scooter Discussion' started by Wizard2003, May 23, 2017.
  1. Wizard2003
    Wizard2003 Member
    Trying to find a carb repair kit for my Peugeot Zenith M year 2000. Anybody know anywhere online I could get one or is there a universal one?
    Thanks
  2. Tamiyacowboy
    Tamiyacowboy Pippa's Owner
    Piaggio Skipper
    need to find out what carbs fitted dello or khien , once you know that you can do a quick search for rebuild kits ;)
  3. Wizard2003
    Wizard2003 Member
    And how would I find that out :D
  4. Sam phantom
    Sam phantom Active Member
    Euroscooter parts list your bike
  5. Wizard2003
    Wizard2003 Member
    So its a
    Peugeot Kymco SYM Vertical Engine Carburettor
    Who new!!! :D
  6. Stevep
    It's stamped into the side of the carb
  7. Wizard2003
    Wizard2003 Member
    Had a quick look there during lunch break. Can't take it apart until I get home. But looks like it says Partner France?? :confused:
  8. Sam phantom
    Gurtner carb
  9. gilburton
    gilburton Active Member
  10. Wizard2003
    Wizard2003 Member
    Thanks guys! :D
    Will get it ordered asap.
  11. gilburton
    Same as speedfight I believe?
  12. Wizard2003
    Wizard2003 Member
    Unfortunately they don't deliver to Northern Ireland. But now I know what I'm looking for I can get it somewhere else. Thanks :)
  13. Wizard2003
    Wizard2003 Member
    Guys if theres a problem with the float will this help? Don't want to spend £12+ if I'm going to need a new carb anyway!
    Don't think you can buy the float separatly!
  14. gilburton
    As long as the float isn't leaking it will as you get the needle valve in the kit.
    Take the float out and shake it to see if it has any petrol inside.
    Look at this kit the needle valve is the square shaped item with the pointed end.
    Having said that have you actually checked to see if the float or needle valve are faulty?
    Easiest way is to remove the carb and turn it upside down(or remove the float bowl) and blow in to the fuel feed and you'll feel it shut off/open if you lift the float or turn the whole carb.
    http://www.ebay.co.uk/itm/Peugeot-S...005457?hash=item464e845291:g:ZRIAAOSw7ehXRE~2
  15. Wizard2003
    Wizard2003 Member
    Im pretty sure the float itself is ok. I did the shake test before!
    Haven't blown into it though!
  16. gilburton
    What actual problem are you having? If it was flooding that would point to a float/needle problem.
  17. Wizard2003
    Wizard2003 Member
    Yeah about once a week it floods and have to take it apart!
  18. Sam phantom
    Have You checked the choke is still operating as it should I have just replaced mine on my gurtner with a Manuel choke so much better than those progressive auto chokes
  19. Wizard2003
    Wizard2003 Member
    How would I check it?
    Would it affect it like that?
  20. gilburton
