Help , bleeding front brake
Discussion in 'The Workshop' started by Mehmet, Dec 31, 2008.
  1. Mehmet
    Mehmet Active Member
    AUDI A3
    I got the kit from halfords, done all the shit it told me to, undone the niple connected the pipes....everytime i pump the brakes it throws the fluid out....then sucks back in :confused:
    help is apprechiated ...thanks
  2. numanoid1704
    numanoid1704 New Member
    b
    pull the lever then do the nipple up,let the lever go loosen nipple pull lever tighten nipple.repeat until no air bubbles show in fluid from tube.keep an eye on the resevoir make sure its topped up. :D
  3. MiNoR cOnFuSiOn
    fill the tube your using with fluid befor anything... then loosen the nipple off a little bit and just slowly tickle the lever. will feel when theres pressure in it an then you pump full strokes on the lever, slowly but smoothly. once it resists with no bubbles tighten the nipple then tickle the lever and the pressure will fully come back.. if it doesent whip the caliper off, pump it so both pistons come out, hold the caliper with the nippe at the most vertical point and slowly loosen, press the pistons in and air will come out. then tighten and repeat
  4. Mehmet
    AUDI A3
    there is no air bubles or air locks left inside now.....and the leaver still feels empty :(
    fucking typhoon :mad:
  5. Mehmet
    AUDI A3
    Shall i suck and do it manually
  6. shiny red
    shiny red New Member
    if the pistons are close to the disk tighten up the nipple and quickly pump the brake lever a verry small distance for a long time. foam will come up into the resivoir
  7. px166bajaj
    px166bajaj Active Member
    Another way to get a result is to pump the lever a few times THEN quickly open and shut the nipple. The master cylinder on these bikes is like a Rat's willy, it doesn't move a lot of fluuid in one go like a car cylinder.
  8. Mr_Al1
    Mr_Al1 New Member
    lmao :w00t:
  9. tweak
    tweak Member
    you've done the 'difficult' bit so its simple...
    leave the lever pulled in overnight (use some overcomplicated holding device if you wish; laccy band) and... magical working brake in the morning.
    *allows remaining 'foam bubbles' to rise through system*
  10. WOLFFY
    WOLFFY New Member
    Zip tie FTW
  11. scorpio_-_kid
    scorpio_-_kid Member
    had the same problem on my typhoon . the cable is beinsqueezed by sumfin take off the front panel so u can see the cable
  12. scorpio_-_kid
    3-4 times of bleedin u feel should the brake gettin hard
