Help ASAP gilera runner?
Discussion in 'The Workshop' started by Joeva10, Dec 6, 2013.
  1. Joeva10
    Joeva10 New Member
    Help me ASAP, had my ped not running for over a year and finally bought a new battery and some petty and 2t
    But it still won't start, you can hear the ignition relay click, and jus to note the kick start don't work?
  2. richard
    richard New Member
    have you checked the starter motor?
  3. mourneman
    mourneman Member
    VivaCity 50cc
    the starter might be stuck try giving it a tap with a spanner or hammer to see if it frees up.
    have you checked that the engine will turn over ?
  4. Joeva10
    Joeva10 New Member
    Basically what happend is I went to start it about a year ago and it's started turning over and then jus stopped, doubt it will be starter motor tbh though.
  5. Stevep
    If it's been that long I would have turned it by hand first with a socket on the flywheel nut and the plug out. Stick some oil down the hole and turn it a few times to put a film of oil back in the barrel. Might be worth a piston ring check now.
  6. Joeva10
    Joeva10 New Member
    Tbh mate I don't know too much about press so it could be hassle trying to do that
  7. Joeva10
    Joeva10 New Member
    Does anyone know if here's any instructions online on how to clean the carb?
