Yesterday morning i got my aerox out of the garage and put the choke on like normal,kicked it and it went to start but then died and wouldnt start after that.ive got a good spark and plenty of compression as i have have just put a new piston and ring in about 100miles ago.fuel is getting into the carb but doesnt seem to be getting into the head,i have cleaned the carb out with carb cleaner and an air line and put it back and after kicking it about 30 times it started and ran fine,But then this morning it wouldnt start,i repeated the process of cleaning the carb but it wouldnt start. hopefully somebody might have a clue to what it is thanks for ready
What makes you think fuel isnt getting to the cylinder? Have you tried putting fuel striaght into the head?
See if the spark plug spark when u kickstart.... If cast spark, you have eliminated the electricity. Then is a problem in fuel supply.
