HELP 100cc speedfight not starting
Discussion in 'The Workshop' started by danny-p, Jun 18, 2011.
  1. danny-p
    danny-p Member
    SMC NMF 90cc
    i own a 100cc speedfight and it broke down on me the other night is kept on cutting out then bam just stoped all togeather i have checked the carb, jets and the float chamber and there fine could anybody help me with wat it could be its doing my head in :banghead: thanks for the help :)
    danny-p
  2. gazell
    gazell Active Member
    you checked that youve got a good spark. check your plug and your ht lead. it might have came loose
  3. Gamble
    Gamble Member
    Also check that you've got compression, could be your piston rings.
  4. danny-p
    danny-p Member
    SMC NMF 90cc
    cheers will check the piston thanks
  5. Hackett Sr
    Hackett Sr Member
    check the air filters clean aslwel
  6. Alexdaboom
    Alexdaboom New Member
    It also might be worth checkin the reeds, pull em out and hold them up to the light see if the petals let any light through, or look for an cracks in the petals? And yeah like gamble said check the compression, anything over 90psi should be ok.
