helo
Discussion in 'Scooter Tuning' started by waynesworld, Feb 9, 2015.
  1. waynesworld
    waynesworld Member
    Hi don't no if any one can help me I have a neos 50cc with a stage 6 pro rep exhaust with a TNT 21 mm carb jet 100 and a open air filter rollers are 5g and the rest is standard the neos gos really well but want to make it more tuned the bike is not for every day use just to play around with need some help to choose the other parts that will work well the rest
    Need
    70cc kit
    Race cluch and springs
    Gear up kit
    Race variator
    Crank
    If any one can help Me want As much torque a possible
    Thanks
  2. Stevep
    Doppler crank with C3 high speed bearings
    PM Tuning or Malossi top end
    Keep the standard clutch but use stronger springs, then play with the roller weights and jetting.
    I did one but kept the carb to a 17.5mm dellorto, goes like a scalded cat and hits 65 on the flat.
  3. waynesworld
    waynesworld Member
    Hi stevep
    65 on the flat that's good going I was thinking one of the stage 6 high end kits but don't no how good that are
