Headrace bearings fitting
Discussion in 'The Workshop' started by Storm, Oct 27, 2013.
  1. Storm
    Storm Member
    Nothing atm
    Hi there,
    I was wandering if there was anything I can do to press the bearing seats into the stem without having to use a press tool?
  2. Stig
    Stig Well-Known Member
    EXUP1000
    if everythings spotlessly clean use a flat surface (ideally a larger diameter than the outer race) and gently drift it in making sure its sitting square as you do it. They dont need alot of pressure. i tapped mine with a soft faced mallet to get it started and then put a bit pf plate over the top to continue.
    Alt you could thread a long bolt through the stem hole with big washers on each end and then tighten them up to pull it in
