Headlight switch issue
Discussion in 'The Workshop' started by craig c, Aug 1, 2019.
  1. craig c
    craig c New Member
    Hi,
    I have a WK Bellissima 50CC and the high beam light won't come on when using the right-hand switch, but it comes on when using the pass light switch.
    The switch on the right has 3 clicks - OFF / Low beam / High beam.
    Low beam works on the right hand switch but high beam doesn't. Now I know it's not the bulb because it works fine when using the pass light switch on the left and I've found nothing wrong with the wires, nothing loose and nothing split.
    Any ideas as to why its not working from the main switch?
  2. Stevep
    dirt on contacts inside switch
  3. scubabiker
    Some bikes are like that. My China cubs are like that
  4. Mark Emerson Trentham
    Sandpaper & contact cleaner.;).
  5. craig c
    craig c New Member
    Thanks all. I guess it was the contacts. I managed to remove them all and just decided to replace them with some new ones, after that everything worked fine.
