head problem
Discussion in 'The Workshop' started by alex_1966, May 1, 2008.
  1. alex_1966
    alex_1966 New Member
    one of the cylinder head nut is rounded pretty bad asthe socket i was using was pretty naff , anyway i can get it off by cutting it but i desperately need it fixed for work and il have to wait ages for a replacement nut
    its tight but not set to the correct torque like the other 3 and was just wondering if it will be okay like this until i get a new set of nuts ? im guesiin it wont but is worth asking anyway ;)
    cheers :beer:
  2. MiNoR cOnFuSiOn
    cut the nut off... remove the barrel and then wind 2 niuts onto the thread.. tighten one into the other then unscrew the thread
    in future use GOOD tools.. this shit dont happen then.. bet it was an imperial socket ay :D
  3. alex_1966
    yeah need to get a better torque wrench the one ive got is a cheapo :p
    and it was metric , 10mm :bird: ;)
    cheers for the help minor always aprreciated :D
  4. MiNoR cOnFuSiOn
    if it was a metric 10mm how the hell did you round the bolt off... not possible wihtout poor tecnique :confused: (or chocolate sockets)
  5. alex_1966
    yeah ,bad technique really , i could barely get themassive torque rench in a tiny gap between the head bolts and a suopporting bar in the frame the geniuses at yamaha decidied to put right in front of the spark plug .... flippin hate aerox's :p
  6. MiNoR cOnFuSiOn
    buy
    a
    knuckle
  7. alex_1966
    is that the right angle sort of joint peice ?
    got one for my halfords socket set , dosent fit the torque wrecnh though :(
    next time i do any top end work im just gona get the engien out , is ALOT easier to do that on a aerox than to strip all the panels off and take of the suspension , again ... aeroxs suck :p
  8. MiNoR cOnFuSiOn
    reducing socket/adaptor down to 3/8 drive onto the smaller knuckle. done
    having the right tools makes live VERRY easy
