Okay, ive recently been doing wheelies and sometimes i hit the front end down very hard, ive stopped now due to whats happened, but i my coolant bottle has a tiny crack in it by the mount and its leaking onto the radiator and steaming, the bottle is also loosing water, which isnt good if i want to go anywhere. my friend says the headgasket is gone so it blew a crack in the bottle, i highly doubted that, but i have noticed when im sitting idle in traffic lights that the idle starts picking up quite a bit, usually this is from an air leak, but it may just be out of adjustment, can someone try and clear things up for me a bit, thanks for reading Matt
Okay will check the head today, do you reckon putting sealant on the crack will fix the water bottle? or should i just melt the crack together?
Okay, strangely, my Circular head gasket was broken, but the outer gasket was fine, the spark plug hole is also cross threaded, i have got another head to put on and a new gasket, do you think this will stop my problem of running lean/out when i go full throttle?
will do, i found water in the piston, so my headgasket was definetly gone, also, where abouts are the temprature sensors on an aerox?
