Worth buying or not ? After picking up a cheap ludix blaster I'm looking at doing a few bits and pieces to tidy this little neglected scooter. It's mostly cosmetic, not sure why you'd take most of the panels off ? I'm not keen on the spray from the front wheel going everywhere and why would anyone be ? ( middle aged scooterist syndrome ) So, is the Haynes manual worth buying ? I'm happy to admit that my knowledge of twist and go scooters is very limited but are they all basically the same, mechanically, as the Haynes manual is obviously a bit generic. Thanks Sean. Sent from my LG-D855 using Tapatalk
+1 on this . they can be very useful, if your able to also grab a copy of the service manual to, they will have a lotta torque settings for the bolts and likes and usually give you a full panel strip down guide . electricals your going to be decamping most if not all the bodywork just to get at the loom, a loom replacement means a whole body work removal ( they tend to shove starter relays and fuse boxes up the rear end, and the reg/rect and winker/headlamp relay up the font end good to have that sorta info on a page or two saves one stripping half the scooter naked on the front end to find they shoved the cdi/ fues box in the tail lol)
