well im having trouble getting the crank in the cases, ive got the bearings on the crank and im trying to get the crank into the right hand case but it just aint happening, ive heated the case and sprayed the bearings with freeze spray and the crank goes in just under half the way but wont go any further?? does any one have any tips on helping the crank slip in? thanks
mine slipped in fine using the heat/cold thing... put the crank in the freezer, and heat the casing with oxy acetalene... worked a treat.
cheers mate cranks in the freezer now and im going to heat the case up with a blowtorch, hopefully that will get it in imp:
oops forgot to write about the crank anyway ive had the crank in the freezer for 2days now and it still wont go in anyfurther than half way
