Katana barrel - two broken exhaust mounts still usuable if your smart. Katana reed block - also usable for minarelli engines. Katana inlet and spacer, plus gaskets Katana carb aerox 100 carb weber carb for 50 piaggio engines dellorto 12mm carb - needle missing Rear brake shoes for piggy 50's hardly used +small dru,m 125's led flashing light for cyclone alarms front pulley fans front pulley Fan cover over ac piggy barrel zip std lightbulb catalyzer block Flywheel fan Oil pump 50 variator bushing LC flywheel cover for both hyper 1 and 2 tranny case induction zip belt nrg/runner/ice etc belt std reedblock and inlet rear output shaft nut and shell std clutch without springs kickstart kickstart cogs Neons flywheel - 10 plus postage Stage6 torque controll clutch 45 posted Malossi ignition 50 posted stage6 belt 5 malossi straight cut gears 50 posted malossi clutch 15 posted straight inlet for 21mm carbs 10 posted polini torque springs 10 posted zip/runner shocks 5 each +p Items are free if they havent got a price on. just pay postage or come collect. Can get more pics if needed pm me
Re: Having a clear out. mainly 50 bits but maybe adaptable 4 dont know mate it came off a runner 50 engine (hyper1)
Re: Having a clear out. mainly 50 bits but maybe adaptable 4 how much for the red rear shock inc post.?
Re: Having a clear out. mainly 50 bits but maybe adaptable 4 Could you get a pic of the 'tranny case induction' and the straight inlet. and how much would postage be? Thanks
