Hard to get to bolt on the trans case
Discussion in 'The Workshop' started by haugh, Sep 4, 2007.
  1. haugh
    haugh New Member
    Yes its the The Generals trans case but how do i get the lil anoying bolt out :(
    I used a ratchet set for all the other bolts but on the 8mm socket theres a bit that comes out and gets in the way!!! :rtfm:
    GRRRRR
    If i can im gunna swap them all for srews the same size & length
    Sorry about the pic :emb:
  2. J-Nitro
    J-Nitro Active Member
    Yep the quality on that pic is lovely! :w00t:
    how loose is the bolt? what do you mean - like the scoket heads are topo fat to fit past the trans case grooves
    if its loose, thin needle-nose pliers.. still trying to think of a method if its tight! ....
    maybe... 8mil spanner?
  3. haugh
    haugh New Member
    click the photo it might help a bit lol
    I've tried the 8mil spanner still no good :(
    and no its not loose
    u kno on the socket its smaller at the 8mil end and it gets bigger at the other end to fit on the ratchet
    like this:
  4. tErr0
    You need a 1/4" 8mm deep socket. If you are using a 3/8" ratchet then you need an adapter.
    It's the only way you can undo every trans casing bolt and never fuck up the trans casing. ;)
  5. haugh
    haugh New Member
    Alright cheers :)
  6. haugh
    haugh New Member
    http://www.argos.co.uk/webapp/wcs/store ... x=0&go.y=0
    This is what i got could i get an adapter for it from Homebase or B&Q or the likes?
    I've damaged most of the trans casing grinding bits away with a dremel to get the socket to fit, it worked for only one bolt lol :(
    so im gunna strip the paint off it and polish it etc
  7. Sw1fT
    Sw1fT Active Member
    200SX S13
    that socket set is aweful and at a guess i reckon you'll get about a minutes use per pound you spent
  8. haugh
    haugh New Member
    Well its fine, just hasn't got what i need which is deep sockets ;)
    Which is because i didn't know i needed it at the time i bought it :(
  9. Sw1fT
    Sw1fT Active Member
    200SX S13
    it might be ok for a while but i wouldnt go tightening anything too tight, and rusted bolts are a no no in my opinion.
  10. haugh
    haugh New Member
    Do you know if i can get an extension for it what terro was talking about?
    Could you show me a pic of what it looks like if so?
  11. Sw1fT
    Sw1fT Active Member
    200SX S13
    yeh i know what he means, best bet is to go down to halfords or the equivalent and see if they sell them, its just a longer version of what you have.
  12. J-Nitro
    the adapter is like the shape of that socket you have in your picture, should come with most cheap socket sets or a full expensive one, it will fit in a large drive extension bar or rachet head and then the drive on the end will be smaller e.g. 1/2" drive to a 1/4" drive for smaller sockets to clip on
    go for something like a good halfords set, doesnt have to be halfords proffesional, dont go for anything less than chrome-vanadium - they are very hard wearing tools and pretty gd value a decent set should set you back anywhere between £25-£40+, my local garage has a good set he bought when he was 14, hes now 37
    edit: an interesting fact about adapters - you cant get any with a life time guarantee, not even snap on do guarantees with them
    and the trade name for them is also called "reducers" heres a piccy haugh of some impact reducers/adapters:
  13. haugh
    haugh New Member
    So i look for them and i can get an 8mm deep socket to fit the ratchet set i have from argosa few posts above?
  14. J-Nitro
  15. tErr0
    The set you linked is a 1/2" drive so completely useless for pretty much everything on a scooter.
    Halfords sell both the 8mm deep socket and an adapter for 3/8" to 1/4".
    I use my 3/8" set for everything apart from trans casing bolts where i used what i already described.
    This is the set i have and it's a great little set. Alot of useful things in a small box. The only downside is the ratchet is a little shit but a halfords pro 3/8" fits in there perfectly. It's CR-V even though it doesn't state it is.
    http://www.screwfix.com/app/sfd/cat/pro ... 0&id=23867
  16. J-Nitro
    my mistake
    i was just giving ideas of prices
  17. tErr0
    Probably should have quoted. I ment haugh's argos one.
  18. haugh
    haugh New Member
    I went to halfords, got the adapter and 8mm deep socket... to find out it spins on the bolt o_O
    Have no idea how im going to get the bolt off :(
  19. capri dave
    capri dave Active Member
    Try a 7mm socket!!
    if its too small you can hammer it on (carefully)!!
  20. haugh
    haugh New Member
    Will pop back to halfords 2moro and buy a 7mm deep socket :(
