Gy6 Ignition coil catching fire!
Discussion in 'The Workshop' started by Gelatin.Skeleton, Apr 3, 2019.
  1. Gelatin.Skeleton
    Gelatin.Skeleton New Member
    When key is turned to on position the ignition coil appears to be getting constant power, heating up, and smoking. New ignition coil, same thing. I can't find anything online where someone has had the same problem. Anyone know what's causing this???
  2. MARSH
    Faulty voltage regulator?
  3. scubabiker
    Cdi wires shorting out?
  4. Stevep
    Coil wired to ignition circuit/direct to the battery?
