Install new ignition and adjust the ignition Malossi innerrotor ignition Preparations - Wash the scooter, especially the engine - Disconnect and remove the battery. Disassembly - Minarelli engines 1. Remove the coolant pump 2. Loosen the three nuts that drive the cooling pump and remove them from the flywheel. 3. Unscrew the nut that locks the flywheel on the crankshaft, remove the flywheel using the flywheel puller. 4. Remove the coils, the pickup and cables Assembly Pic 01 Old ignition have I removed earlier Pic 02 Old gasket fitted Pic 03 Then Malossis bottom plate It is not possible to mount it wrong Pic 04 The key, I already mounted on the crankshaft Pic 05 Then the rotor is mounted Pic 06 I locked the transmission on the other side Pic 07 Now I just pull the bolt a bit but later it shall have it tightened to 30Nm Pic 08 Then stator and wiring harness Pic 09 Tighten the three bolts slightly Pic 10 Mount the dial indicator in the spark plug hole I will now find out top dead center (T.D.C.) Pic 11 I turn the crank counterclockwise until the pointer on the clock changing direction Pic 12 Now I've reached the top dead! Then I reset the clock Pic 13 I keep turning the crank counterclockwise (each turn of the clock is 1mm pre-ignition) The manufacturer recommends 2.3 mm pre-ignition (see Table 1 below) Table 1 Recommended pre-ignition (2.3 mm or 32-33 degrees) Pic 14 There I have 2.3 mm! Pic 15 Aligne rotor and stator referencemarkings Pic 16 Tighten the bolts Pic 17 The reference marks on the stator and rotor lined Pic 18 Now, tighten the bolt to 30Nm (I have locked variator on the other side again) Pic 19 The plate for the water pump drive fitted Pic 20 Transfer the three bolts for the water pump drive from the old flywheel to the new plate Pic 21 One of three bolts in place Then install the waterpump in the usual way
