You need A grinder Dremel 565 Multipurpose Cutting Kit Carbide cutters picture 01 Original crank diameter is 72mm and Malossi crank diameter is 75.5 mm So I have to make some room for the larger crank picture 02 I have made a template with dimensions 76.4 mm (diameter required for the crank is 76.5 mm). The inner rod has a diameter of 46.5 mm and is the measure bearings has. Tip Check figure 8 if you wonder why the template should be less picture 03 I use the template when I scribes the lines. picture 04 I use a Dremeln to cut I have already adjusted the depth to be cut Tip A cutter with a flat top is preferred picture 05 I cut anticlockwise Tip I made a block in the middle to easier cut vertical picture 06 Stay off the line! NOTE Beware gasket surface! picture 07 With sandpaper remove any edge in the bottom picture 08 Once the template is in the bottom I check with a 0.10 mm feeler gauge for roughness One half finished picture 09 The other half i have to cut deeper picture 10 I scribes contour in the same manner picture 11 This time i have to do the job in two separate rounds picture 12 First round picture 13 Now it's time for some freehand milling Tip Take one third at a time picture 14 Feel with your finger if you got rid of the edge picture 15 Check the model if it is in place Once it is in place, you are ready picture 16 Completed! picture 17 Original rod about 72mm long NOTE - I should have measured from the center of the shaft but I was a bit tired... But you know what I mean . picture 18 Malossis rod about 80,5 mm long In other words, Malossis crank is more than 8mm longer than a stock crank! NOTE - I should have measured from the center of the shaft but I was a bit tired... But you know what I mean ...
