I have previously processed the engine block to fit my Malossi big bore cylinder Now it's time to cut out the transfer channels and boost channel. The effect increases due to the flow of fresh gases in the crankcase gets better. Check out the Youtubeclip at the end picture 01 Use the cylinder basegasket as a template picture 02 Use a scribe to mark where you should cut Tip Screw the template with studs and nuts so it stays in place picture 03 This is the "transfer channel" picture 04 This is the "boost Channel" picture 05 Other "transfer channel" picture 06 Cutting down the channel towards the line Tip I use a cutter with a rounded top picture 07 Try to keep the same angle (slope) of the channel You should not cut out the bottom of the channel Tip Dont press hard Move counterclockwise picture 08 I grind the edges of the channel with the larger cutter NOTE! Be careful do not to scratch the gasket surface picture 09 I then use a smaller cutter to be able to fix the corners Then take the other corner in the same way picture 10 I finish the surface with a grindingstone Tip The surface should be as if it were sanded with 240's grit paper picture 11 I verify that the port is in line with the channel picture 12 Then do I second transfer channel in the same way picture 13 Then the boost channel The same tool and method as previously picture 14 A file makes it easier to fix the corners Follow my continued work with my Malossi Big bore 87cc In the next step, I cut out the block for the crank with the long rod
