You need to be extra careful when you install a "Hyperkit" First - Wash all parts with gasoline and clean with compressed air! Picture 01 The piston ring must be measured and adjusted if necessary Picture 02 Push the pistonring about 5mm into the cylinder Picture 03 Push the piston up from the bottom so that the pistonring aligns Picture 04 Now are the pistonring in the correct position to be measured Picture 05 Measure with a feeler gauge opening on the piston ring The gap should be 0.15 mm Picture 06 How it should look like according to Malossis drawings Picture 07 If you need to adjust the gap, you should file a with a diamond whetstone "outside to inside" This is to maintain the coating on the pistonring Picture 08 You must also grind off the corners so it will be 45 degree angles Picture 09 Fit a circlips NOTE Make sure it ends up properly in the groove The end of circlips must be vertically Put a rag in the engineblock, If you drop anything Picture 10 Put oil on the crankshaft bearing Picture 11 Push a piece of the piston pin into the piston NOTE You should not install the piston ring yet Picture 12 Push the piston pin so it touches the circlips you mounted And mount circlips the same way as on the other side NOTE The arrow on the piston must point down (towards the exhaust port) Inserting the cylinder and aligne the piston Picture 13 I install new studs with threadlock on Picture 14 Insert the cylinder base gasket and push the piston in the cylinder without piston ring Picture 15 Put washers on the cylinder and tighten the nuts on the studs Picture 16 Crank the handle gently by spinning the variator Check if the piston hitting anything in the engineblock Picture 17 Check with a feelergauge if the piston is aligned in the block NOTE If the crankhalfes are processed wrong or if the crankshaft is bent you have a problem... But everything was perfect in my case with a new crank and all. Adjust squish First fit the medium size cylindergasket Do not apply the piston ring yet Picture 18 Cut two pieces of solder that are approximately 1 mm shorter than the width of the piston Picture 19 Tape them on the piston Picture 20 Fit the head, tighten it to the correct torque (1.2 Kgm) Picture 21 Crank the piston about 5 laps Picture 22 Measure the flattened solder. How to measure: - Measure the smallest place - Calculate the average of the two value Check the table (Table 2) included with the kit which value you must have You may experiment with the cylindergaskets to get the desired measurement Table 2 In my case: - The gap on the pistonrings should be 0.15 mm - "Squish" measurement should be 0.8 mm - And I need a sparkplug W34ES-ZU Picture 23 Do not forget to install the pistonring Picture 24 Lubricate the cylinder and mount it Picture 25 Attach the head and all O-rings NOTE - Clean the head carefully first - Do not forget the O-rings and make sure they are all in Picture 26 More O-rings .. Picture 27 And this one.. Links to Malossis assembly instructions Done! Soon it's time for the carburetor, etc.
