grrrr I just cant get it right
Discussion in 'General Scooter Discussion' started by Dr MamBo, Jun 16, 2008.
  1. Dr MamBo
    Dr MamBo Member
    Ok so I have my new stage 6 exhaust fitted, upgraded the clutch springs, lightened the rollers from 5g to 4.5g and upjetted from size 70 to size 74. My scoot still feels underpowered and wont go past 25mph.
    When I just had the size 70 jet in it would hit 45mph but it was woefully underpowered and would barely make it up a long hill. It also took quite a while to hit the speed, revving really high all the way up.
    Advice please?? :(
  2. alex_1966
    alex_1966 New Member
    if you put a bigger jet in and it goes slower then it means your running to rich , think about it ;)
    if its revving too high thats normally a sign the rollers are too light
  3. Dr MamBo
    Dr MamBo Member
    well even if I did think about I wouldbnt get anywhere. Im totally new to all this engine tuning malarky.
    What exactly does too rich mean?
  4. nibbles
    nibbles Active Member
    as far as i no to much fuel
  5. Dr MamBo
    Dr MamBo Member
    right
    so when I turn the screw on the carb out, does that lessen the amount of fuel going in or increase it?
    I would assume turning it out increases it, but its best to be sure.
  6. kyle1b1
    normally screwing it out will richen it.
    but that is only at idle is the main jet that determins fuel/air mix at full throttle.
    if it reels like its revving more than it is pulling try heavier if its revving excessive,
    ad have a few reads of minors carb tuning guide will help ALOT !
  7. Dr MamBo
    Dr MamBo Member
    its not revving more than its pulling now. It gets to 25 then pretty much sits there. Its not revving high at all and I would say te revs are about mid range as its not really pulling as fast as it used to with the stock set up but its not revving really low either.
  8. kyle1b1
    whats take off off like feel normal or down too ?
    does it splutter at any point ?
  9. Dr MamBo
    Dr MamBo Member
    take off is down too. It used to get up on the back wheel with ease but now theres no chance.
  10. kyle1b1
    you say you fitted stronger clutch springs yeah ?
    maybe try abit lighter rollers,
    i dont really know minarelli motors.
    have a read of minor carb guide and dont confuse rollers with jetting.
  11. Dr MamBo
    Dr MamBo Member
    yep I fitted stronger clutch springs....or at least I assume they are stronger. I put in green polini springs. They would be stronger that the stock springs right?
    I did order some 4g rollers too but pmtuning didnt send them in my last order or inform me they were out of stock and now i'm skint until I get paid on the 25th :(
  12. kyle1b1
    yeah they will be stronger should be able to tell will rev higher before the bike starts to move.
    maybe have a few read round a few aerox threads to getsome roller weight ideas
  13. Dr MamBo
    Dr MamBo Member
    I suspect rollers is the issue here.
    How can I tell I have got the jet size right? I have a 72, 76 and a 78 jet lying around. What would happen if I put those in?
  14. kyle1b1
    run richer :pimp:
    if you gone from a 70 to 74 for a pipe should be ok.
    when you get it running something like,
    go on a run get a decent bit of road where you can get a decent bit of full throttle action then pull over whip plug out and see what colour is it.
    should be a chocolatly brown
  15. Dr MamBo
    Dr MamBo Member
    right you are. I have the day of tomorrow so thats what i'll try.
    Thanks for the help ;)
  16. lol
    lol New Member
    r u sure that the pipe aint got restritors in it as this is wat me 70 done when i put my yashuni on i didnt no it came with restritors
  17. Crana
    Crana Active Member
    Clutch springs? Makes sense it can only be the things you messed with...
  18. Dr MamBo
    Dr MamBo Member
    Yeah my pipe has been derestricted, I made sure of that.
    So what would happen if I went back to stock springs? I upjetted and lightened the rollers also as well as the new pipe, so it wasnt only the clutch springs I messed with.
  19. Crana
    Crana Active Member
    You might have broke the springs? Also try the other rollers in and test?
  20. Dr MamBo
    Dr MamBo Member
    the springs went on fine. I got my dad to help me with that bit. He was a mechanic for 30 years so he'd make sure the springs went on right.
    I might have to try the old rollers just to see what happens. Cheers.
