Got my new pipe finally..quick question.
Discussion in 'General Scooter Discussion' started by Dr MamBo, May 29, 2008.
  1. Dr MamBo
    Dr MamBo Member
    I used the search and trawled through a ton of posts but couldnt find what I was looking for so..
    In the end of my new pipe, where you bolt it to the engine there is a cone shaped wotsit soldered in place. Is that the restrictor? is it safe for me to remove it?
    Cheers!
  2. Purplepill
    Purplepill Member
    No you didnt......... :msn1:
    But yes, thats the restrictor, get rid of it.
  3. Dr MamBo
    Dr MamBo Member
    I actually did, it brought up over a thousand results but none of the ones i looked through described a cone shaped restrictor.
    Ta for the help ;)
  4. Dr MamBo
    Dr MamBo Member
    How do I get that restrictor out? From looking at it, it appered to be soldered in place but my soldering iron does nothing to it.
  5. nibbles
    nibbles Active Member
    its a weld mate use a dremmil and grind it out in small enough pieces that they will fall out if you just try smash it in itll fall inside and youll have hell gettin it out
    nibbles
  6. Dr MamBo
    Dr MamBo Member
    right you are, cheers mate ;)
  7. alex_1966
    alex_1966 New Member
    lol nah welded , solder isnt going to stand the heat of the exhaust fumes is it lol
  8. Dr MamBo
    Dr MamBo Member
    well i thought that but then it was just what it appered to be at first glance.
