well i got my kit and ive got a few questions 1- the new kit does not include exhaust studs can i use my old ones? 2 th cylinder is covered in all this stick stuff what is it? cheers
the sticky stuff is cutting oil from when it was made i believe. I used my old exhaust studs in mine.
i cant get my old ones out for the life of me any tips as to how to get them out?? if not will these fit http://cgi.ebay.co.uk/NEW-Starway-Chunl ... dZViewItem
yeh i was just looking into that amd ve found out that my trans case bolts go straight in but they are too long
the 2 extreme kits are covered in an oily resiue to protect the heat proof paint from stratching off and damaging it, bolts should be around in a typical bike shop file around the exhaust tract with some thick paper such as p60 or 80 and finish it off with a bot of emery or p600/800 to then rinse off any iron filings or the oil off the barell with rubber gloves (NOT LATEX) and some paraffin or thinners, for 5 to 10 minutes with a toothbrush make sure every spec of dirt is gone then rinse off the cleaning agent you use with water and throughly damp it dry with a clean towel to stop rust + oil it with 2 stroke oil and assemble my 2 extreme kit didnt come with an exhaust gasket so make sure you get one too mate
yeh mine came with this exhaust gasket kinda thing but my exhaust alredi has one one it can i not just use that ? oh and ive sorted the bolt thing now cheers
yeah the ring is a gasket, i had to cut mine down when i temporarly fitted a tecniwank the gasket you have on now, clean it thoroughly with grit paper if its a metal one or best buy a new papery/metal type every time you put the exhaust off always change the gasket, always :w00t:
i think i may have misunderstood i was talking about the thing that holds the exhaust onto the cylinder?? should there be another thing like that? if so i havent had a gasket on mine so far :emb:
you get that sticky stuff when you buy brake disks for cars ect think its to pretect the fresh metal imp:
well me and monty fitted the kit mainly monty gotta thank that guy hes a fucking diamond.cheers mate :up: :beer: ruuning well now....fazster than my 50 and it still need setiing up but im hapy with it. gona order some rollers...and jets for the 20.5 and hopefully get a bit more speed out of it overall i WOULD deffinately recomend the kit for anyone on a tight budget.
