X reg piaggio zip 11k miles on the clock (black) Needs little work put through MOT. : (Under braking) Steering Headbearing has excessive free play. :Exhaust is leaking and excessiveley noisey. Already know how to sort the exhaust out - new gasket. £150
if your going to change your headrace bearing then make sure you get some hight quality grease (lithium i think is the best) and use a good amount. Bad grease will make the bearing wear faster. when putting it back together make the races a touch tight, this should loosen up after 1-2 miles. its a good idea to check them after a small ride . hope this helps dan
