got a bit throttle happy
Discussion in 'General Scooter Discussion' started by rideorcollide, Feb 6, 2008.
  1. rideorcollide
    rideorcollide Active Member
    TYPH 172
    ok so i was riding on my old typh 70 once, and at a set of lights on the a40 (the ones at north acton just before the hill to be precise) a pizza guy pulled up on his 125 wankstroke pizza ped.
    turns out he wanted a race, so after i battered him i was still full throttling (had been goin for about a minute flat out) and it just cut out. it did it a couple of times before but it always starts straight back up after so what could it be??
    i thought maybe the cdi was shorting out at max revs or sumthing but i dunno!
    someone giv me a clue wat this was coz ive always wanted to know why the f**k it did this
    o yh and how long is it safe to full throttle on a 70 for (polini sport wc) because with the 50 o have now i just hold it open all day long but im scared that wen i fit my kit i might get a bit greedy for speed and blow the cunt up.
    :D :D :D
  2. monty9120
    monty9120 Active Member
    Vespa gts300
    erm ages it depends if it overheats. runs out of oil, or the kit just falls apart from over revving
  3. rideorcollide
    TYPH 172
    so is there no chance of the cdi or something electrical just getting fried
  4. monty9120
    Vespa gts300
    not really no. if one fails it fails doesnt matter if you doing 10 or 70
  5. JakeSP
    JakeSP New Member
    Plug cap ok?
  6. wobbly_trials
    partially blocked fuel filter/tap
    cant feed fuel in quick enough and drains the flaot bowl.
  7. am4n_am4n
    am4n_am4n New Member
    maybe your throttle is out of the throttle housing....
    happened to me once on my old runner so i took the panels out and put the housing back together and started up perfectly
    best way to check is to see what postion the slider is at in the carb
  8. runner 180
    runner 180 New Member
    that happen to 172 typhoon in the mornings on the way to work and it turn out to be heat sized and the bore and piston was scored but i dont no if it was because never had the black casing over the head
  9. Major Rel14b1lty
    Major Rel14b1lty New Member
    Thats gota been the most stupid thing ive read all fuking day
    Cause it was, without it all the flow of air from the cooling fan is just a fuking waste, whats there to cool it without it other then breeze
  10. frainey
    frainey New Member
    And he still fucking won in the end :rofl:
  11. rideorcollide
    TYPH 172
    thats exactly wat it used to do a while ago when i had a 2xtreme kit fitted with no air cover but then i changed the kit nnd got an air cover.
