good morning everyone
Discussion in 'Introduce Yourself...' started by mourneman, Jun 14, 2013.
  1. mourneman
    mourneman Member
    VivaCity 50cc
    new to scootering I have a vivacity 50 which has been sitting in my back yard for 5 years . it belonged to daughter she rode it to college and then to work till her boyfriend fell off it and convinced her it was dangerous so it not been started for 5 years anyway im waffling now lol. I decided to use it to get to work be cheaper on fuel than my l200 pick up. I have stripped it down to the bare frame (after I managed to get all the bind weed un tangled from it) cleaned the rust of and primed it for now have done the same with all the plastic . will it pass mot not being the proper colour
  2. scootzmadness
    hi and welcome to the forum :)
    mot testers wont even check the logbook sometimes so wont care what colour it is :) but dvla should be told asap about colour change and if it hasn't been ridden and not insured you may want to quickly tax/insure it or sorn it, dvla are cracking down on untaxed/uninsured vehicles
    edit : if your changing colour tell them but if its in primer there wont be any bother about it :) as its seen as temporary :)
  3. mourneman
    mourneman Member
    VivaCity 50cc
    its only primer it going for mot on Saturday if it passes then I will strip it down and paint it properly I think every thing else is ok ( some of the panels are held on with zip ties )
  4. scootzmadness
    I doubt they'll even be bothered about primer, zip ties could be an issue though if you get a fussy tester, put some bolts in where you can (if you can) then zip tie whats not secure, but make sure you cut down the excess cable, makes it look tidier and they wont moan as much, good luck with mot :)
  5. mourneman
    mourneman Member
    VivaCity 50cc
    cheers thankyou
  6. supraking
    supraking Well-Known Member
    Honda MSX125
    welcome along, looks like a great project to get in to
  7. mourneman
    mourneman Member
    VivaCity 50cc
    hi thanks.
    looks like I got more work to do failed mot front forks and wheel bearings . more oil under the finger nails lol
  8. scootzmadness
    fork seals ?
    wheel bearings are relatively easy to do if you have the right tools
  9. mourneman
    mourneman Member
    VivaCity 50cc
    got lots of tools .prob don't have the right ones. just have to figure out how to do it . need a manual of some sort.
  10. scootzmadness
    im busy fixing a computer problem but ill have a look through what manuals I have on my computer and see if I have the one u need
  11. mourneman
    mourneman Member
    VivaCity 50cc
    That would be a great help if you have. Thankyou
  12. technodimwit
    technodimwit Active Member
    Honda X8R
    hi and welcome to the club
